ArduPilot and the Iridium Certus satellite service
Satellite links are often the only option for BVLOS and remote operations, so I’ve been investigating the reliability of the Iridium Certus satellite service for ArduPilot (MAVLink) telemetry.
There’s a few manufacturers that produce modems for the Certus service (in particular GroundControl, who supplied a modem for testing), that are quite small and lightweight (<1kg typically), making them ideal for unmanned vehicles.
The Certus service has a number of different datarate tiers, from 100-700kbps. The higher tiers require larger modems and antennas though. For the purpose of these tests, a Certus 100 service was used, giving 88Kbps downlink and 22Kbps uplink. Note that the uplink (Vehicle to GCS) is the critical datarate, as most telemetry data flows in that direction.
I tested ArduPilot telemetry over an Iridium Certus 100 connection using a RockREMOTE UAV OEM modem, measuring latency, packet loss, and overall reliability under a range of configurations, using the mavlinklinktester software.
What I found was:
  • A streamrate of 2Hz telemetry is needed (instead of the default 4Hz) to avoid flooding the link
  • Using a “direct” connection (not using a VPN) gave 7-8% packet loss over UDP and 0% loss over TCP. Latency was 800ms for UDP and 1.2sec for TCP.
  • VPN services (such as Wireguard or Zerotier) were not practical to use. Packet loss and outages were a minimum of 50%.
  • For a stable service, the antenna should be place at or above the treeline/roofline. Any sustained ground testing should ensure the antenna is elevated to this height to give representative results.
In terms of airtime costs, running at a 2Hz streamrate will typically cost around $30/hour.
The full report is attached below.
Writeup.pdf (370.2 KB)
Excellent ! That is quite some way from the old iridium SBD … still expensive thus, but could be interesting in some applications
Did you look at the power consumption ?
It was around 7W
Hi. So what server did you use then?
I used the ArduPilot UDP Proxy.
