forgot to tell you its in rc9 , please check
Yeah, I had just downloaded RC9 just prior to that.
Hi Ruben,
I was just checking the widget layout on the TX16S again in the course of setting up another copter.
The transmitter battery and Armed/Disarmed section in the top bar are still obscured by some flight mode names.
There’s something in the top left corner of the top bar (just left of Armed/Disarmed circle) and I dont know what that is, I cant seem to activate it. Does it need to be there, or could it be smaller?
Hi , what version of the app and what type of vehicle (what params have you for frame ) ?
I’m running into the same thing on the top bar. Beta 1.2 rc10. The radio is a TX16s on 2.12.4
I have to say, I really like how easy it is to install the maps.
Edit: Flight modes for rover on the radio hud are also reporting incorrectly. I left an issue on git but that was just for the desktop. On the app I haven’t tried everything but I’ve noticed that Manual is reproted as Stabilized, Circle is reported as Land and RTH is reported as Drift.
This is for Beta 1.2 RC9
Tested copters were QuadX (FRAME_CLASS,1 FRAME_TYPE,1) and OctaQuadX (X8) (FRAME_CLASS,4 FRAME_TYPE,1)
Hey guys , thanks for the feedback , ill check it out.
@xfacta @Allister i gave a bit more attention to the radio widget , addressed your feedback and slightly made it look better
I guess RC11 will be needed … maybe today…
Thanks - I’ll try it out when I see a new version ![]()
Tested the radio widget - I like the new screen for editing widgets, very nice.
The widget top row now works on a TX16S - the TX battery and LQ are visible while selecting typical flight modes, as is the arming status.
I’ll mess around more and try the Taranis widgets too, and will provide feedback if necessary.
Hey glad it works and you like the change. thanks for the feedback and testing , much apreciate it.
I received an update today, but the Android version seems to remain at 1.0.0. Just curious: since there is no mention of changes on the Google Play Store, what is the difference? Is the EKF or Vibration status instrument added?
build number 1.0.0(12)
Hi
This GCS looks great and finally looks like app from 2026. I have a questions about survey option:
In “Survey(Grid)” option in “Mission Planner” in third tab “Camera config” there are different options for “Trigger Method”. This features are useful in different situations. For me most important is possibility to use “DO_SET_SERVO” on beginning and ending of each flight path. That’s needed for LiDAR scanning from the UAVs. Did you implement something similar in ArduDeck ?
Also is there a possibility to load my map with the heights of the ground (DEMs, DXF, point cloud, OBJ) to have more accurate relief of the ground and based on that to have possibility to plan the altitudes of flight in survey mission for photogrammetry or scanning ?
soo in Ardudeck desktop there is something new coming a new App and cargo , Locus is all about surveys and computation of LIDaR/Photogrammetry and it will allow you to import those data.
Mobile app is a slight simplification of the Desktop app (that btw runs on any desktop platform).
The Desktop app is general much more complex and provides you with much more option for mission planning and surveys.
Oh and in Desktop you have servo/relay set , repeat
One thing I would like to give feedback on Android platform, ArduDeck needs internet and Google Play account signed in to start, whereas MP does not. Android 8.x on Skydroid H12 Pro.
Thanks for the report! The Google Play version includes Play’s install protection, which needs a Play account. For devices without Google Play, like your H12 Pro, please install the APK from ardudeck.com instead. It has no such check and runs fully offline.
Yes, now H12 Pro without internet and Google account, works.
On another Android device, the installation process reported failure (Files by Google), but in the background it did install (1.0.0 (2011)).
Great , regarding errors , there is not much i can do its something related to google.
