Beta 1.2.
This button does not trigger any action and misleading.
Hey thanks for this details , that will , help there was a fix for rtsp , but im not sure if it also fixes your issues , could you try the rc4 ?
But beta 1.2 is not yet released just to be clear , when you mention a rc of a upcoming version , please mention the RC version (Release Candidate)
Yep its a regression bug , thanks for the report.
Apologies, ArduDeck-0.1.2-rc4-win-x64.exe is the exact version what I used to test and report.
The Beta 1.2 version wording is what I copy from the UI.
Hey thanks , that helps , im working on a fix , right now , but i can not capture in my test harness the issue , any additiona details you can share , network , i dont know anything ?
@Jai.GAY can you please tell this : %APPDATA%@ardudeck\desktop\media-bin\win32\ffmpeg.exe: does it exist, how big is it (should be roughly 80 MB), and what does ffmpeg.exe -version print in a terminal?
Yes.
PS C:\Users\XXXXX\AppData\Roaming\@ardudeck\desktop\media-bin\win32> .\ffmpeg.exe -version
ffmpeg version 6.1.1-essentials_build-www.gyan.dev Copyright (c) 2000-2023 the FFmpeg developers
built with gcc 12.2.0 (Rev10, Built by MSYS2 project)
configuration: --enable-gpl --enable-version3 --enable-static --pkg-config=pkgconf --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-zlib --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-sdl2 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-dxva2 --enable-d3d11va --enable-libvpl --enable-libgme --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libtheora --enable-libvo-amrwbenc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-librubberband
libavutil 58. 29.100 / 58. 29.100
libavcodec 60. 31.102 / 60. 31.102
libavformat 60. 16.100 / 60. 16.100
libavdevice 60. 3.100 / 60. 3.100
libavfilter 9. 12.100 / 9. 12.100
libswscale 7. 5.100 / 7. 5.100
libswresample 4. 12.100 / 4. 12.100
libpostproc 57. 3.100 / 57. 3.100
Thanks all seems fine please try rc5 ive added some fallbacks and more logging Release Beta 1.2 RC5 · rubenCodeforges/ardudeck · GitHub
Oh ya. We use Skydriod H12 pro and at the computer following the manual to set up the network interface for windows MP or QGC to use UDP connection.
Oh ya, I install the android version on the H12 PRO, after some struggle, I managed to get the video feed displayed on the RC.
Im confused , i thought the video does not work on desktop , your screenshot are from desktop.
But you are saying android ?
Yes, Android is just another exploration for us. We need both. Apologies for the confusion.
Ahh ok , please keep me updated on android feedback , very useful, thank you.
And what about rc5 , did it work ? Any new logs you could share (ive added some) ?
@Jai.GAY ?
@Jai.GAY the rc5 has much more logs now , can you please paste the console output when you try to connect ?
There is also a diag button , try the source when it fails click on it
it copies diagnostic in buffer , send it to me via PM .
Here. By the way, it is not easy to paste the message from the console here. The messages are not properly aligned. Right-click does not have the copy option.
10:15:26.150 i Opening UDP :14550...
10:15:26.152 i Port opened, waiting for MAVLink heartbeat...
10:15:26.621 i Connected to ArduPilot Quadrotor System ID: 1, Component ID: 1, MAVLink v2
10:15:26.636 i Armed state: init → false base_mode=0x51 system_status=3 armed_flag=false sysid=1 compid=1
10:15:26.636 > MSG #0 sysid=1 compid=1 seq=243 len=9
10:15:26.667 > MSG #77 sysid=1 compid=1 seq=244 len=10
10:15:26.668 i Board type: MicoAir743v2 (ID 77266944)
10:15:26.668 i Board UID: mavlink-1
10:15:26.668 i Firmware: Quadrotor v4.7.1 (official)
10:15:26.668 > MSG #148 sysid=1 compid=1 seq=245 len=72
10:15:27.956 i RC override released
10:15:27.957 > MSG #111 sysid=1 compid=1 seq=246 len=13
10:15:27.957 i Requesting parameters via MAVLink FTP (fast path)...
10:15:27.961 > MSG #0 sysid=1 compid=1 seq=247 len=9
10:15:27.991 i Loaded 5771 parameter definitions for copter from disk cache
10:15:28.615 > MSG #0 sysid=1 compid=1 seq=248 len=9
10:15:29.614 > MSG #0 sysid=1 compid=1 seq=249 len=9
10:15:29.761 i H.264 relay started with libx264
10:15:29.944 > MSG #110 sysid=1 compid=1 seq=250 len=9
10:15:30.296 i Requesting mission from flight controller (MAVLink v2)...
10:15:30.424 # Received MSG #44 (len=4): 01 00 ff be
10:15:30.425 # Mission has 1 items (payload len: 4)
10:15:30.425 > MSG #44 sysid=1 compid=1 seq=251 len=4
10:15:30.425 # Requesting mission item 0 (MAVLink v2)
10:15:30.615 > MSG #0 sysid=1 compid=1 seq=252 len=9
10:15:31.644 # Retrying stream rate requests
10:15:33.956 # FTP: OpenFileRO timeout (attempt 1/5)
10:15:36.964 # Received MSG #73 (len=37): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 ff be 00 00 01
10:15:36.964 i Downloaded 1 mission items
10:15:37.464 > MSG #30 sysid=1 compid=1 seq=86 len=28
10:15:37.958 # FTP: OpenFileRO timeout (attempt 2/5)
10:15:40.964 > MSG #30 sysid=1 compid=1 seq=186 len=28
10:15:41.964 # FTP: OpenFileRO timeout (attempt 3/5)
10:15:43.934 > MSG #77 sysid=1 compid=1 seq=30 len=10
10:15:45.965 # FTP: OpenFileRO timeout (attempt 4/5)
10:15:46.096 > MSG #33 sysid=1 compid=1 seq=130 len=28
I couldnt get Ardudeck 1.1 to find the radio, a TX16S on EdgeTX 2.11.2
- The radio show as “TX16S” in the file explorer. I also tried the SD Card by itself, no difference.
- O/S is Debian 13
Is Ardudeck looking of a particular name or something?
Maybe we need a selection that points Ardudeck to the correct SD Card where it is not automatically identified.
Also I could not do a firmware upgrade to 4.7.1 on a Cube Orange - the DTR error trying to connect to bootloader mode. Ardudeck misses the bootloader mode and automatically reconnects normally after a short time.
I was doing a bug report about the radio widget/SD Card issue and the “Encrypting report…” is taking forever. I’ll see if I can attempt a firmware update again and gather the logs.
Ok so you are talking about the edgetx widget right ?
Its still experimental and ive tested it only on TX that i have at hand , i will check the TX16s why it is not working , perhaps soem differences
RE the Cube orange , i literally flashed yesterday one , try the RC5 of Beta 1.2
Yes, the EdgeTX radio widget
I was replying to your post about it.
I installed 1.2 RC5 from .deb and get the same errors trying a firmware update. I also tried the app image, same errors. QGC app image worked OK (and also MissionPlanner on windows 11 running in VirtualBox)
22:05:15.685
i
Opening /dev/ttyACM0 @ 115200...
22:05:15.690
i
22:05:15.695
i
Connected to ArduPilot Octorotor
System ID: 105, Component ID: 1, MAVLink v2
22:05:15.696
[MAIN] Failed to set DTR/RTS: Error: Operation not supported, cannot set
22:05:15.697
i
base_mode=0x59 system_status=3 armed_flag=false sysid=105 compid=1
22:05:15.713
i
Board type: CubeOrange (ID 9175040)
22:05:15.713
i
Board UID: mavlink-105
22:05:15.713
i
Firmware: Octorotor v4.7.1 (official)
22:05:15.772
i
22:05:16.240
i
22:05:16.262
i
Loaded 5777 parameter definitions for copter from disk cache
22:05:16.507
i
Downloaded 1356 parameters via MAVLink FTP in 0.3s
22:05:17.836
i
Telemetry rate: normal
21/21 cmds sent - ATT 30Hz, POS 10Hz, OTHER 5Hz
22:05:21.337
i
22:06:08.702
i
Fetching ardupilot versions for copter/CubeOrange...
22:06:08.711
i
Fetching ardupilot boards for copter...
22:06:08.712
i
22:06:11.917
i
Found 9 version groups (48 total versions)
22:06:12.165
i
Found 436 copter boards
22:06:12.371
i
22:06:14.347
i
Detected 1 board
22:06:14.349
i
Auto-detecting board on /dev/ttyACM0...
22:06:15.358
[MAIN] [SerialTransport] Drain timeout or error, continuing with close
22:06:15.459
[MAIN] [SerialTransport] Warning closing port: Port is not open
22:06:16.467
22:06:16.567
22:06:17.570
22:06:17.670
22:06:18.673
22:06:18.775
22:06:19.777
22:06:19.877
22:06:20.881
22:06:20.982
22:06:20.982
Could not identify board on /dev/ttyACM0
22:06:21.006
i
22:06:21.014
i
22:06:34.988
i
Downloading firmware 4.7.1...
22:06:34.989
i
Firmware downloaded to /tmp/ardudeck-firmware/Copter_CubeOrange_4_7_1.apj
22:06:34.995
i
Flashing firmware to CubeOrange...
22:06:34.995
i
Flasher type: ardupilot, path: /tmp/ardudeck-firmware/Copter_CubeOrange_4_7_1.apj
22:06:34.995
i
Board: {"name":"CubeOrange","boardId":"CubeOrange","port":"/dev/ttyACM0","detectionMethod":"vid-pid"}
22:06:34.995
i
Routing decision: isApj=true, isArduPilotBoard=true, apjOnUnidentified=true, useArduPilot=true, hasPort=true
22:06:34.995
i
Using ArduPilot bootloader flasher (.apj file)...
22:06:34.996
i
Starting ArduPilot bootloader flash: /tmp/ardudeck-firmware/Copter_CubeOrange_4_7_1.apj
22:06:34.996
i
Port: /dev/ttyACM0, Board: CubeOrange
22:06:35.019
i
APJ firmware: board_id=140, image_size=1644436, padded=1644436
22:06:35.129
i
Ports before reboot (6): /dev/ttyACM0, /dev/ttyACM1, /dev/ttyS0, /dev/ttyS1, /dev/ttyS2, /dev/ttyS3
22:06:35.129
i
Sending MAVLink reboot-to-bootloader command...
22:06:35.136
22:06:38.341
i
Reboot command sent, scanning for bootloader port...
22:06:41.294
i
Original port reappeared: /dev/ttyACM0
22:06:41.795
i
Using port: /dev/ttyACM0
22:06:41.797
i
Serial port opened at 115200 8N1
22:06:41.798
i
Sync attempt 1/3...
22:06:41.798
22:06:42.100
i
Sync attempt 2/3...
22:06:42.412
i
Sync attempt 3/3...
22:06:42.734
Initial sync failed, attempting bootloader reboot...
22:06:42.838
i
Attempting MAVLink reboot to bootloader...
22:06:42.840
22:06:46.045
i
Reboot sent, waiting for bootloader...
22:06:50.048
i
Sync attempt 1/5...
22:06:50.049
22:06:50.349
i
Sync attempt 2/5...
22:06:50.661
i
Sync attempt 3/5...
22:06:50.992
i
Sync attempt 4/5...
22:06:51.314
i
Sync attempt 5/5...
22:06:51.740
x
Firmware flash failed
Could not connect to ArduPilot bootloader on /dev/ttyACM0. Make sure: 1. The board is running ArduPilot firmware (not Betaflight/iNav) 2. The board has the ArduPilot bootloader installed 3. No other application is using the serial port If the board does not respond, try disconnecting and reconnecting USB.
found the issue , fix will be in RC6
I might also be having issues with downloading logs and opening .bin logs since changing to 1.2 RC5 - I’ve had a download freeze Ardudeck (the FC was OK) and could not open any logs, Parsing error. \[MAIN\] Error occurred in handler for 'log:parse-file': {"code":"ERR_INVALID_ARG_TYPE"}
This would have been a log from 4.6 or an early 4.7 release candidate.
I’ll try to test a bit more.
EDIT:
yes, I went back to 1.1 and I can download logs OK and open logs OK
More:
in Flight Logs I dont get a map or terrain in Flight Path, but I do get all maps, terrain and layers in both Telemetry and Mission Planning screens. I’m sure I used to get terrain and all in flight logs in an earlier version. I cant find anything blocking this at my end, but it’s possible.
