Hey everyone , Beta 1.2 is out ![]()
First the personal part. This release is dedicated to Sir Patrick Stewart , who passed away this week. For me he was one of the best captains: serious , but kind , focused , and principled. He is the reason I went the scientific path , and a good part of why this app exists. My condolences go to his family and to his close friends. The longer note is here: Thank you, Captain - ArduDeck Blog.
Now , what changed for you. Beta 1.1 made the map the cockpit. Beta 1.2 is about the hour before you get there , and about trusting what you see once you are up. 140 commits , 13 release candidates , and a lot of it came from your issues and PRs , so thank you. Here it is , screen by screen.
Set up a new vehicle. The new wizard takes a fresh build from the box to Ready to arm: how big is it , how do the motors sit , which way is the board mounted , connect your receiver , which compass , what does the mode switch do , check the motors , battery and failsafes. Planes get their own path (measure the wing , what makes it go , how it takes off , wing and tail , control surfaces , airspeed sensor) , VTOLs answer how they hover and whether the lift motors help in plane flight , rovers and boats how they steer and what drives the motor. Every choice has a pictogram , nothing is written until you have seen it.
Quick Setup. Pick how you fly (Beginner , Cinematic , Freestyle , Racing , Long Range for copters , Trainer , Sport , Glider , Long Range FPV , Flying Wing for planes) , check the transmitter , review every parameter it is about to write , apply. The Quick setup tab in the configuration view also shows the Something wrong cards (it will not arm , it flips on take-off , motors do not spin , it wobbles) , recommendations for this aircraft that you stage and review , and hardware cards that check each device against what the board reports.
Configuration rebuilt around questions. New tabs: Arming (why it will not arm , with the 18 pre-arm checks as cards) , Autotune (axes , how hard , how to start it , no parameter hunting) , Hardware (the flight controller and every device on its DroneCAN bus , official product names) , DroneCAN (nodes , their parameters , bus health) , LEDs and Sound , Logging , Sensors , Telemetry rates , Plane tuning with rate and throttle response plots , Rover navigation and speed and steering. New cards: Board orientation with a 3D board model you turn with 90 degree buttons , Compasses , GPS wiring and antenna position , GPS diagnostics read straight from the receiver , Return home with RTL height and its safety parameters (#98) , Vibration filter with notch analysis , Stick assignment. Servo Output cards show the live output , min , trim and max , and the real FC values (#146). Every parameter change goes through a compare modal before it is written.
Also in configuration: battery voltage multiplier from a voltage you measure (#144) , compass fit panel , clearer AHRS orientation picker , Rover modes recognised (#147) , -1 accepted where the docs say it means off (#135) , FBWA named correctly.
Telemetry screen. In-flight adjust: speed , altitude and loiter radius without leaving the flight view (#141) , as an instrument on the map and in the command popup. Instruments can be grouped: drag one onto another and they share a tray , drag it out to split. Layout presets (Pilot cockpit , Minimal , Strips only , Split cockpit , Rover) set up a whole cockpit in one click , and the Instruments catalog gives every instrument analog , numeric and strip variants with its own size. New instruments: Messages , sensor readouts , numeric readouts , RTK , link , sticks. Native joystick support (#128): axes and buttons per channel , reverse , safe zone , on-screen virtual sticks when nothing is plugged in. Distance sensors draw a proximity ring around the aircraft (#137).
Fleet vehicle focus. With several aircraft connected , calibration , motor and servo test , RC override , the FTP browser , CAN bus stats , logs (list , download , erase , format) , DroneCAN node restart , parameter reads and reboot act on the vehicle you pick in the fleet strip , over whichever link carries it , and replies only count from that vehicle. Each fleet vehicle keeps its own armed state. Check the focus before you calibrate , there is a tour for it.
Surveys. Corridor width now comes from the camera footprint: with no strip count given , ArduDeck lays out the fewest strips whose photos reach both edges , spreads them evenly , adds an edge margin and draws the band on the map. An explicit count keeps the old spacing. No photos on turn loops and end overshoots anymore , so the trigger count on the plan is what you get. Grid surveys got a turn guard. Save a survey as a project in the Library , insert a waypoint between two , heading per waypoint (#140) , set or shift all heights at once , and restart / go commands follow the right waypoint again (#127).
Video. Synthetic vision and the 3D Sim World publish through the MediaMTX hub (rtsp://127.0.0.1:8554/vision and /sim_world) , also over SRT and WebRTC in a browser. Custom SRT and WHEP sources , a recordings and snapshots gallery , camera settings for RunCam WiFiLink / OpenIPC , 3D buildings in synthetic vision with an offline bake , RTSP fixed on Windows , FPV reconnection fixed.
Radios and links. CRSF telemetry from an ExpressLRS backpack: set Telemetry Mode to WiFi in the ELRS Lua script , join the backpack network , pick CRSF and ArduDeck listens on 14550. Position , attitude , altitude , battery , mode and link quality , read-only , nothing changed on the aircraft. Arming sends no RC override while a transmitter is live or RCMAP is unknown and the release frame really releases (#152). USB serial on Windows got a critical fix plus a DTR toggle and diagnostics. DISTANCE_SENSOR shows correctly in the inspector (#137) , MAVFTP robustness from jlpoltrack (#131). The Radio HUD for EdgeTX got a template gallery (Copter , Survey , Cinematic , FPV , Rangefinder work , Long range) , a tile inspector and a redesigned monochrome rendering for sunlight-readable radios.
Simulator. Launch SITL and the simulator from the app: pick where you fly , the vehicle and the conditions , fly over the 3D Sim World. Environment simulation (wind , turbulence , battery voltage override) and failure injection for compass and baro live in the SITL view , the Test Conditions panel in the 3D Sim World adds GPS denied / glitch / jam , sat dropout , high vibe , motor out and radio loss. SITL max speed , home position picker , swarm SITL fixed on Windows (#133).
Five languages. English , Deutsch , 繁體中文 by phoenixlin2007 (#151) , 简体中文 by Li-T-1025 (#155) and Українська (beta) by PapaJustifyTV (#160). Settings , Configuration , Language , or follow the system. The translating guide is in the repo if you want yours in.
Tours and guides. Seven tours new or rewritten (Vehicle setup , Sensor calibration , Instruments on the map , Projects , Quick Setup , Fleet vehicle focus , Mission planning with corridor width , turns , waypoint heading and projects) and eight guides with demos (map and vision side by side , workspace layouts , instrument grouping , simulate before you fly , telemetry from an ExpressLRS backpack , add features with cargo , adjust while flying , ArduDeck speaks your language). All replayable from Settings.
New cargo in the Hangar. Six new ones since Beta 1.1 , all public: Lua Graph Editor (wire Lua scripts from blocks) , Operational Volumes (the three volumes of an authorisation on the mission map) , UAV-DEV (their hardware under official names) , MGRS (grid references for emergency crews) , AI Agent Bridge (MCP) (Claude Code , Codex or Cursor talking to ArduDeck over MCP) and Sonar (fish-finder echogram from a Blue Robotics Ping). All install from the Cargo Bay. The cargo manager also takes keys for experimental versions , checks for updates , and loads a cargo from a folder for developers.
Bridge theme. Not a feature , the tribute. Beta 1.2 is dedicated to Sir Patrick Stewart , who passed away this week , and the Bridge theme is how the app carries that. The personal part is in the note above: Thank you, Captain - ArduDeck Blog. The tribute itself is in the app and the first launch introduces it , no spoilers here.
Locus. Some of you asked what happens with the survey data after the flight. ArduDeck Locus is my answer , and it integrates with ArduDeck: it installs as a cargo from the Cargo Bay , the surveys you fly with ArduDeck land in it , and what it builds (terrain , orthophoto , 3D model , obstacle fences , landing sites) goes back onto the mission map with one click.
Locus is in closed beta. If you want in , DM me here or on Discord.
Also in there: FFT spectrum in the Log Explorer (#148) , Electron upgrade , a performance pass (no more stutter on tablets when the sidebar collapses) , UDP and TCP receive buffers bounded , licence files sorted so the AppImage shows in public catalogues.
Upgrading. If you are on Beta 1.1 , the app updates itself , or grab the build for Mac , Windows or Linux here: Release ArduDeck Beta 1.2 · rubenCodeforges/ardudeck · GitHub. Full notes are in the release.
As always , tell me what breaks and what you flew. Issues on GitHub are gold , a thread here is gold too , cheers!
