We are trying for arduCopter on PX4, but we are not getting the servo ouput values aswell as the rc input values on the qground Control dashboard.
[color=#000080]Thanks and Regards,
Himanshu Kamat.[/color]
@HimanshuKamat,
How are you powering your PX4? A full up PX4 system cannot be powered by just the USB alone. You must use a powered USB hub to supply enough current for the PX4 to operate properly. Are you using a PPM receiver or are you using a receiver to PPM encoder? The PPM encoders take a lot of power and a powered USB hub should be used with the PPM encoder.
Have you followed these instructions: copter.ardupilot.com/wiki/px4fmu … io-wiring/
Regards,
TCIII Admin
We are not using ppm encoder but we are using ppm receiver… and using the separate Li-po 2200 miliamp battery to power the quad-copter.
