My team is using a Pixhawk 4 running ArduCopter firmware to run a small quadrotor. Though the vehicle has successfully taken off and flown missions, there are a number of sensor faults that appear upon startup, and persist throughout operation.
The faults can be found below:
[01/01/70 00:00:03] INFO: Fault: SENSOR_3D_GYRO
[01/01/70 00:00:03] INFO: Fault: SENSOR_3D_ACCEL
[01/01/70 00:00:03] INFO: Fault: SENSOR_3D_MAG
[01/01/70 00:00:03] INFO: Fault: SENSOR_ABSOLUTE_PRESSURE
[01/01/70 00:00:03] INFO: Fault: SENSOR_GPS
[01/01/70 00:00:03] INFO: Fault: SENSOR_ANGULAR_RATE_CONTROL
[01/01/70 00:00:03] INFO: Fault: SENSOR_ATTITUDE_STABILIZATION
[01/01/70 00:00:03] INFO: Fault: SENSOR_YAW_POSITION
[01/01/70 00:00:03] INFO: Fault: SENSOR_MOTOR_OUTPUTS
[01/01/70 00:00:03] INFO: Fault: AHRS
[01/01/70 00:00:03] INFO: Fault: TERRAIN
[01/01/70 00:00:03] INFO: Fault: LOGGING
[01/01/70 00:00:03] INFO: Fault: SENSOR_BATTERY
fault: 2 healthy: 0 enabled: 1 present: 1 mask: 1
fault: 3 healthy: 0 enabled: 1 present: 1 mask: 2
fault: 4 healthy: 0 enabled: 1 present: 1 mask: 4
fault: 5 healthy: 0 enabled: 1 present: 1 mask: 8
fault: 7 healthy: 0 enabled: 1 present: 1 mask: 32
fault: 12 healthy: 0 enabled: 1 present: 1 mask: 1024
fault: 13 healthy: 0 enabled: 1 present: 1 mask: 2048
fault: 14 healthy: 0 enabled: 1 present: 1 mask: 4096
fault: 17 healthy: 0 enabled: 1 present: 1 mask: 32768
fault: 18 healthy: 0 enabled: 1 present: 1 mask: 65536
fault: 23 healthy: 0 enabled: 1 present: 1 mask: 2097152
fault: 24 healthy: 0 enabled: 1 present: 1 mask: 4194304
fault: 27 healthy: 0 enabled: 1 present: 1 mask: 33554432
Interestingly, each of these faults shows that each sensor seems to be enabled and present, but not healthy.
To clarify, the above bits correspond to the following:
/** @brief These encode the sensors whose status is sent as part of the SYS_STATUS message. /
#ifndef HAVE_ENUM_MAV_SYS_STATUS_SENSOR
#define HAVE_ENUM_MAV_SYS_STATUS_SENSOR
typedef enum MAV_SYS_STATUS_SENSOR
MAV_SYS_STATUS_SENSOR_3D_GYRO=1, / 0x01 3D gyro | /
MAV_SYS_STATUS_SENSOR_3D_ACCEL=2, / 0x02 3D accelerometer | /
MAV_SYS_STATUS_SENSOR_3D_MAG=4, / 0x04 3D magnetometer | /
MAV_SYS_STATUS_SENSOR_ABSOLUTE_PRESSURE=8, / 0x08 absolute pressure | /
MAV_SYS_STATUS_SENSOR_DIFFERENTIAL_PRESSURE=16, / 0x10 differential pressure | /
MAV_SYS_STATUS_SENSOR_GPS=32, / 0x20 GPS | /
MAV_SYS_STATUS_SENSOR_OPTICAL_FLOW=64, / 0x40 optical flow | /
MAV_SYS_STATUS_SENSOR_VISION_POSITION=128, / 0x80 computer vision position | /
MAV_SYS_STATUS_SENSOR_LASER_POSITION=256, / 0x100 laser based position | /
MAV_SYS_STATUS_SENSOR_EXTERNAL_GROUND_TRUTH=512, / 0x200 external ground truth (Vicon or Leica) | /
MAV_SYS_STATUS_SENSOR_ANGULAR_RATE_CONTROL=1024, / 0x400 3D angular rate control | /
MAV_SYS_STATUS_SENSOR_ATTITUDE_STABILIZATION=2048, / 0x800 attitude stabilization | /
MAV_SYS_STATUS_SENSOR_YAW_POSITION=4096, / 0x1000 yaw position | /
MAV_SYS_STATUS_SENSOR_Z_ALTITUDE_CONTROL=8192, / 0x2000 z/altitude control | /
MAV_SYS_STATUS_SENSOR_XY_POSITION_CONTROL=16384, / 0x4000 x/y position control | /
MAV_SYS_STATUS_SENSOR_MOTOR_OUTPUTS=32768, / 0x8000 motor outputs / control | /
MAV_SYS_STATUS_SENSOR_RC_RECEIVER=65536, / 0x10000 rc receiver | /
MAV_SYS_STATUS_SENSOR_3D_GYRO2=131072, / 0x20000 2nd 3D gyro | /
MAV_SYS_STATUS_SENSOR_3D_ACCEL2=262144, / 0x40000 2nd 3D accelerometer | /
MAV_SYS_STATUS_SENSOR_3D_MAG2=524288, / 0x80000 2nd 3D magnetometer | /
MAV_SYS_STATUS_GEOFENCE=1048576, / 0x100000 geofence | /
MAV_SYS_STATUS_AHRS=2097152, / 0x200000 AHRS subsystem health | /
MAV_SYS_STATUS_TERRAIN=4194304, / 0x400000 Terrain subsystem health | /
MAV_SYS_STATUS_REVERSE_MOTOR=8388608, / 0x800000 Motors are reversed | /
MAV_SYS_STATUS_LOGGING=16777216, / 0x1000000 Logging | /
MAV_SYS_STATUS_SENSOR_BATTERY=33554432, / 0x2000000 Battery | /
MAV_SYS_STATUS_SENSOR_PROXIMITY=67108864, / 0x4000000 Proximity | /
MAV_SYS_STATUS_SENSOR_SATCOM=134217728, / 0x8000000 Satellite Communication | /
MAV_SYS_STATUS_SENSOR_ENUM_END=134217729, / | */
} MAV_SYS_STATUS_SENSOR;
#endif
As I mentioned, the drone operated successfully despite these faults. So are these faults really occurring due to a hardware failure of the drone? Or could they be the result of a configuration option? Or are they not impactful enough and should be disabled if the drone is working?
Thank you for your time!
Jeremy
