Hi there, i have this Spherical 3m diameter blimp with 4 BLDC motors on the hull and two BLDC motors on the gondola for altitude control. When i try to control the motors with either RCIN or Motor functions the ESC keeps rebooting when I move the joystick a little bit. The motor would spin briefly and then reboot. It makes the same beeping sequence when the ESC is connected to power.
Do you know if your power supply (battery pack) can supply enough current for these motors? Do you have a good capacitor on your power input?
A photograph of your setup would likely be helpful for anyone trying to help. Any information you can supply about your components would like be useful too.
I personally would like to see a photograph of your setup because it sounds really interesting.
What ESC is it?
Try doing the semi-auto ESC calibration and see what happens then:
Yes my battery has way more than enough current supply for the motors. I was initially using ArduSub which worked well for me for manual mode but for autonomous flying I could adjust my system to fit the motor functions of Ardusub so I tried to switch to ArduBlimp and the motor functions in Frame 2 match my configuration but when I just move the joystick a bit the motor spins for a split second and then reboots. This doesn’t happen if I move the joystick fast enough. Once the joystick is over rapidly im able to control motor motor speed unless joystick is at center (zero throttle) then the ESC reboots again. My ESC’s are in 3D mode so joystick at center is zero throttle and the motor soins in different directions when joystick is moved up/down from center. The ESC’s I have are Skystars Talon32 40A AM32 ESC Skystars Talon32 40A AM32 ESC - Rotor Village
My ESC is Skystars Talon32 40A AM32 ESC Skystars Talon32 40A AM32 ESC - Rotor Village
Set LOG_DISARMED,1 and use the MissionPlanner or QGC motor test to run each motor for a few seconds. Upload that .bin log somewhere and send us the link to it. Also provide your observations of what happened during the tests.
Since the battery and signal wires are so long from the flight controller to ESCs, you might need to add a ground or 0v wire from each ESC negative back to each of the flight controller servo negative pins. They will be better being twisted with the signal wire too.
I think because I’m using ardublimp firmware, QGC doesn’t have support for motor test (ArduSub had the motor test feature) and for mission planner for some reason for both ardusub and ardublimp motor test feature on mission planner is greyed out. When the esc reboots I don’t see any messages in the console to understand what’s happening as well. I need help with this as soon as possible.
Thanks,
Daniel.
Well set LOG_DISARMED,1 and see if you can make the motors spin somehow.
Post a link to that .bin log and we can go from there.
Also look at the wiring I mentioned - a ground wire from each ESC back to the servo grounds. Twisted with the signal wire.
It was taking forever to download the logs. Whats weird is the motors(x2) on the gondola are slightly different motors from the 4 motors on hull but they use the same ESC’s however they dont stop intermittently.
Anyways, I switched back to ArduSub since all motors operated properly there and i added the follow mode functionality there and added a custom frame that matched my requirements and so far it seems to work on the bench outside. I will be doing flights with everything assembled outside during this week.
