I download mission planner after the first build I got many errors, I corrected them one by one except this error in title above which persists I tried to install sdk windows and change the version of sdk in this file EXTLibs/WindowStore/WindowsStore.was proj but nothing has changed. See the image bellow.
For information when windowsstore is unchecked in batch build the solution compiled
successfully.
Finally, I find the solution of this error.
So the SDK for Windows 10 17134 is missing, I need to install it
Go to Get Tools and features from Tools menu or Run Visual Studio 2019 installer ( C:\Program Files (x86)\Microsoft Visual Studio\Installer\vs_installer.exe ), click on modify , and select 17134 SDK under SDK/framework in individual components tab of the installer:
We’d absolutely appreciate if you tried to follow the wiki instruction/s and had issues, that you might do an update to the wiki … https://ardupilot.org/dev/docs/building-mission-planner.html there is a ‘edit on github’ link, right on the page.
