As you can understand, testing this is scary and risks damage to your aircraft so I’ve not done a lot of it.
I believe you have to actually stall while in an auto mode. Then (probably) some I-terms build up and drive the ailerons/rudder/elevator hard over until you manually recover.
In the video above, I believe the plane was in a spin which needs a more active correction to recover from in short time.
Did you notice that in the OSD video from the cloud penetration, at 12 seconds into the video flight mode changes from AUTO to CRUZ while exactly in this moment the adventure begins.
At 15 seconds (3 secs later) flight mode changes to AUTO again.
Hardly a coincidence, right?
Any theories on this?
Anyway - I see no actual stall-handling code. There is code to maintain desired airspeed, drop nose when needed - but I did not find anything that changes roll/yaw.
what control surfaces did the involved planes had ? ailerons, and rudder or more ?
[quote=“Noircogi”]Switching to manual does work to recover normally.
I think in the video above I just didn’t give it enough time in manual to recover from the extreme state it was in. I knew I was going to lose video any second.
You need to have the onset of the stall occur in an auto mode to get into this state. I know for certain auto and RTL will do it. I believe that it should also happen in cruise but I haven’t seen it myself.
Simply setting FBW_MIN/cruise close to stall speed, then hitting RTL with the plane heading away from launch will probably induce the situation in most cases. Once the spiral dive happens, you can switch to manual and pull it right back out.[/quote]
Flying in fbwa (I don’t have an airspeed sensor) and banking while at too slow an air speed will also cause the death spiral
Happened to me, was flying too slow and didn’t realise it. Made a left bank to come back around and the plane just went full down elevator and full right aileron. Didn’t have time to react as I was at around 10-12meter high, but was high enough to smash in the front of my 1400mm Cessna
I tried to reproduce something similar today after a commercial flight with arspd_use=1 - and covered the pitot.
Took of manually, switched to auto , IAS was ~2m/s min arspd was 13, still - all that happened was that AP leveled wings, set high throttle and lowered nose. , same for cruise and fbw-a
One day with more time to spare I’ll disable arspd_use , and retry then.
