APM Plane "Auto Takeoff" page is blatantly incomplete
The page I’m referring to can be found at:
plane.ardupilot.com/wiki/automat … -Launching
At the bottom of the page, the article describes the conditions that need to be met for APM to apply power. It stops midway through a sentence,
I assume it means to explain that the TKOFF_THR_DELAY value will then begin counting down, and once it’s done the TKOFF_THR_MINSPD value is checked and the throttle is activated. But the page simply stops there. Is this wiki no longer being maintained, or is it simply an oversight? If it’s the latter, I believe it should be finished, up to that point it was quite helpful.
Thanks!
Hi
Thanks for reporting this error. The wiki page had been inadvertently truncated in a previous update and has now been fixed.
I’m moving this to closed - though of course if you have other issues with it please post.
Regards
Hamish
