Hi all
I’m trying to set this up with a spectrum AR8000 receiver on a FX-61 Phantom (wing). I have set the “Wing Type” to “Elevon”, and this works well (without the APM Mini).
Q: Which Rx Inputs on the APM Mini should I use? And which Rx Input controls the auto/manual switch?
A link to a manual would be great!
Have you got a link to exactly which clone you are using?? I would be tempted to try each one they should be mapped in a similar way to a full size APM though.
Clone? Sry.
So even through it’s a “wing” which in manual mode only would need four servos (thro, aile, elev & auto/manual), you suggest that I install it with the regular five servos (thro, aile, elev, rudd & auto/manual)?
I found it in:
plane.ardupilot.com/wiki/ardupla … ur-rc-gear
For elevon only the first three Rx inputs are used + input 8 for switching between auto and manual.
Thank you for your time.
Regards
Chris
