Build:
Turnigy 9x Remote - Firmware upgraded to ER9x & Backlight upgrade
8 ch Receiver
x525 frame
Arducopter running the 3.2
Ublox - 6m GPS
HK 20A ESC running Simon K FW. attached to Turnigy Multistar 980Kv
with 1045 props
The GPS is within 1deg. I have the copter sitting still and I’m watching the Mission planner and the copter is moving around huge sometimes 50’ +/-… even when its sitting perfectly still on the ground with no motors or anything moving. When I’m watching the mission planner it looks like a bunch of noodles all over the place.
I looked at that log, at first I thought that was too much movement and something was wrong. Then I noticed you’re actually flying around. So it would be impossible for me to judge how much GPS drift you’re getting.
In the photo you attached, that amount of movement is not abnormal during start-up, especially if you’re sitting under a roof as indicated by the red arrow?
That is normal if you have it sitting on the kitchen table in the house. You need clear line of site to the sky to get a good lock. If I use mine on the kitchen table it moves around my back yard.
