Apm 2.8 is not arming
Apm 2.8 is not arming while connect to mission planner is connected and arming disconnect flug is disarmed i tried to arm by remote is not arming is arming only when mission planner is connect
GCS failsafes are incorrect. Change that parameter
How to setb failsafe
Disable the GCS failsafe. Why did you enable it in the first place.
When GC S failsafe is active it requires a USB or telemetry link to a GCS in order to arm.
You clearly do not want that, so disable it
Sir is any other way to arm the Quadcopter sir my rudder sticks not working sometimes please tell me sir
this is the problem sir
Are the RC transmitter trims centered?
They must be all centered.
Sir my copter one of the motor is not spinning
You did not answer any of the questions. And you post new questions every time.
I am afraid this is not a productive discussion at all.
