Setup:
APM 2.6
Turningy 9x, radio
9X8C v2 - receiver for the radio.
I am trying to set up my APM 2.6. I am stuck in the radio calibration step, when i move the throttle nothing happens in MP.
This is my issue:
I can bind my receiver to my radio (red light goes from flashing to solid red), then i remove the bind cable and the servo cable that is powering the Rx, everything works as it should. But when i plug the Rx into the APM after a successful bind, i plug it the exact same way as i did when bindning the Rx but without the bind cable, i dont get the red light. When i am just about to plug in the receiver the normal way into the APM there i can see that the light in the receiver is powering on for a short millisecond and then its turned of again. As if there is a connections, but its lost immediately.
Has anyone had a similar issue using thier 9X8C v2 with APM 2.6?
