Hello all,
New to the forums so before I start if this is not the appropriate section to be posting this, I apologize and feel free to move it to wherever it does belong.
I am relatively new to building copters and especially new to the modern tech available for copter and plane builds. I’ve purchased a APM 2.5 incl. 6-pin power module with xt60 connectors and am planning on powering turnigy plush 25a (3) ESC’s. All of the power distribution boards that I have seen available on places such as hobbyking dot com are rated for 20a use max, which are unusable for my build/setup as running at max load I’d probably destroy the PDB with too much draw. I am wondering if it is mandatory that I use a PDB to control the power or if I can use a wiring harness rated for 14/18awg flow with the xt60 connectors (picture included) without damaging the ESC’s/or motors and then just run +/- out to each of the ESC’s using bullet connectors. Is this smart to do and can I do it without causing any damage? Advice / comments would be great.
Comments and help are greatly appreciated as I am really excited to put this thing in the air for the first time. Thank you in advance to all for their time and help on this.
