I have been trying to get RSSI working between an APM 2.5 and a LR DragonLink 2.81.
Result - Killed 2 APM boards…
Killed - Well, they now only work when I put run power to the input and output rails of the APM.
I’m not sure they can be trusted anymore - Thoughts?
So - What did I do, and can any one tell me why it has happened.
Here is what I did…
In Mission planner, You can choose a few options for RSSI_PIN (-1 is off, 0 is A0, and something else is A13 etc).
I set the RSSI_PIN to A0 (and wrote parm) and then plugged the RSSI pins from the Dragon Link to the APM A0 port and it made no difference with TX on or off to the RSSI value in MP data.
So I changed it to A13 to try a different pin (and wrote parm). Plugged the RSSI feed from the dragon link to A13, and pop, apm goes lights out and nothing.
Thinking I may have done some polarity reversal, I then tried a second board. A0, did nothing, and then moved to a13, and lights out again and nothing.
I think it has blown the surface fuse…?
2 boards dead…
So - Dragon link says RSSI voltage is analog - 0.75v for 0% and 3.5v for 100%, so well within the 5v for APM inputs.
Why did A13 kill my board and A0 do nothing with the RSSI?
I can only see RSSI_PIN parm in MP - I can’t see RSSI_RANGE parm, but I can’t see this being an issue…
Any help would be great, but my main questions are as below:
Has anyone connected an APM and DRAGONLINK for RSSI?
++++ If So - HOW?
++++ For ArduCopter or Plane? I do need BOTH…!
Can I still use the boards safely if I power both the input and output rails (Say a Servo Cable from one rail to the other (pos and neg wires only)?
If I do get it working will it show up in MP and will it show up on my Android Tablet via telemetry connection?
Hi - There has been some confusion regarding my connection diagram.
I have attached a modified diagram (v2) as I had drawn the wires around incorrectly.
I had it wired correctly, and all my questions still stand - and it seems no one was done this? I find it hard to understand…?
2 well known items, and no one has done it? Really?
++++ If So - HOW?
if you are flying a quad I wouldn’t bother with RSSI on dragonlink, do a good range check. The dragonlink will have range beyond the flight range of your quad
