I decided to put the APM 1.4 I had laying around in a bixler2.
I had everything working (even got minimosd to work after a lot of frustration), but all of a sudden the apm won’t power up when I connect my battery. A bit strange, cause I never had this problem.
Some thing about the sutiation:
When I plugin the usb it boots up normally
When I power up by usb, then esc, then remove usb it shuts down (saw some some posts about APM 2.5 in the same situation, that keeps running after usb is disconnected)
when esc is connected a blue led on the oilpan lights up and a red one the APM (see photo)
esc provides 5v, and the complete rc rail (where the servo’s connect) is provided with 5v
tried another esc that I know that works, same result
sj1 jumper was/is soldered (even resoldered to rule out)
APM receives radio input (radio calibration in mission planner works fine)
I loaded the recommended bixler parameters I found on the ardupilot site. Not absolutely sure if the problems started after I uploaded these, but could be…)
I don’t think the problem is the parameters, cause the apm boots up through usb.
I know I could power the apm through a separate battery by unsoldering the SJ1, but all my batteries are 3s and the they recommend a 2S-pack (7-11V). I would rather not use an extra battery…
@Rutger,
I have always split the power rails on my AMP1.4s: diydrones.com/profiles/blogs/sim … power-hack
I use a BEC to power the APM and the R/C receiver and the BEC in the ESCs to power the servos.
Chances are the either the Schottky diode or the fuse connecting the output power bus to the input power bus has failed.
Regards,
TCIII ArduRover2 Developer
[quote=“TCIII”]@Rutger,
Regards,
TCIII ArduRover2 Developer[/quote]
Look promising.
So if I’m correct by directly powering the APM through a BEC my problem should probably be solved and as a bonus I get a saver setup.
Could you tell me what BEC you are using? I use 3S lipo’s
And just a thought, but couldn’t I use the powerhack without cutting the trace on the 5V rail?
That way I wouldn’t be needing an extra BEC.
@Rutger,
Any quality BEC of around 3 amps that can handle a 3S LiPo will work. I have used Hobby King and Turnigy. They are all made in China. The more they cost the better they are usually.
Regards,
