Hello there
I’m using a cube orange + with latest stable plane firmware.
I have implemented a function to send the actuators values via mavlink (send_hil_actuator_controls)
I scheduled this function using the scheduler in arduplane.cpp : SCHED_TASK(send_hil_actuator_controls, 30, 200, 49),
On the other side of mavlink is Mavproxy connected via com port and outputing data over UDP to my python script.
I have noticed that I received send_hil_actuator_controls much more than 30Hz maybe 200Hz 300Hz.
I tried to reduced the frequency by a factor of 10 :
SCHED_TASK(send_hil_actuator_controls, 3, 200, 49),
But same result on python side.
Here is a part of the python code :
def hil_actuator_listener():
i=0
while True:
try:
msg = conn.recv_match(type='HIL_ACTUATOR_CONTROLS', blocking=False)
if msg is not None:
i += 1
print(i)
Anyone has a clue of what’s going on ? Is HIL_ACTUATOR_CONTROLS sent somwhere else ?
Thanks
(edit)
I measured the frequency of reception of this message it’s about 2000Hz
HOW
if you are wondering this is the code of the function in GCS_Mavlink.cpp :
void GCS_MAVLINK_Plane::send_hil_actuator_controls()
if (!plane.g.hil_enable) {
return;
float controls[16] = {};
uint64_t now_us = AP_HAL::micros64();
// valeurs normalisées -4500 : 4500
controls[0] = SRV_Channels::get_output_scaled(SRV_Channel::k_aileron);
controls[1] = SRV_Channels::get_output_scaled(SRV_Channel::k_elevator);
controls[2] = SRV_Channels::get_output_scaled(SRV_Channel::k_rudder);
// valeurs normalisées -100 : 100
controls[3] = SRV_Channels::get_output_scaled(SRV_Channel::k_throttle);
// autres canaux disponibles si utile
// controls[4] = SRV_Channels::get_output_scaled(SRV_Channel::k_flap) / 100.0f;
mavlink_msg_hil_actuator_controls_send(
chan,
now_us,
controls,
MAV_MODE_FLAG_CUSTOM_MODE_ENABLED,
0 // flags
