I’ve just released AP_Periph 1.8.0 stable. This has quite a long list of changes since 1.7 was released. Enjoy!
- added BTAG battery information node support for tracking armed hours and cycles
- added DAC (Digital-to-Analog Converter) support
- support for CAN termination control via hardware switch and LED indicators
- support for up to two rangefinders
- added streaming of RPM messages
- support for HiRes magnetometer data
- support for extended ESC status reporting
- support for publishing raw IMU data
- improved ESC rate control with ESC_RATE parameter for RC_OUT peripherals
- added battery state of health reporting
- support for larger RTCMv3 packets (>300 bytes) for newer GPS receivers
- added MCU temperature display in PPPGW web UI
- improved continuous probing for airspeed and compass
- improved DroneCAN servo status simulation for SITL testing
- improved CAN mirroring functionality
- fixed compilation issues with enabled feature combinations
- refactored AP_PERIPH_*_ENABLED defines
- new builds:
- BotBloxDroneNet
- CubeNode, CubeNode-ETH,
- HolybroF4_PMU
- HolybroG4_Airspeed
- MatekG474-DShot, MatekG474-GPS
- MatekL431-APDTelem, MatekL431-BatteryTag, MatekL431-MagHiRes
- MFE_AirSpeed_CAN
- MFE_POS3_CAN
- TBS-L431-Airspeed, TBS-L431-BattMon, TBS-L431-CurrMon, TBS-L431-PWM
- uav-dev_m10s
- uav-dev-powermodule
- VM-L431-Periph-Pico, VM-L431-SRV-Hub-4CHP
