Hello! First and foremost, I am not fully sure if this is the right section to post this so please do correct me if I should move this elsewhere.
I was going through the “Learning the code” documentation when I was attempting to follow along this page: Threading — Dev documentation
Within this document, it states that it is possible to make the following calls to get the micros/millis since the board booted:
hal.scheduler->millis();
hal.scheduler->micros();
I attempted to implement this into the GPS_AUTO_test.cpp library within the void loop()
right before the hal.scheduler->delay(10)
but was met with the following problem when attempting to compile:
../../libraries/AP_GPS/examples/GPS_AUTO_test/GPS_AUTO_test.cpp:150:20: error: 'class AP_HAL::Scheduler' has no member named 'millis'
150 | hal.scheduler->millis();
Upon closer inspection, it does not seem like my IDE can find it either as it says “No member named ‘millis’ in ‘AP_HAL::Scheduler’”.
I tried looking this up online but sadly found no results, is the documentation on this outdated/incorrect or have I perhaps done something wrong?
