Just added a feature supporting both flight controllers that natively support IP-based networking (Ethernet/PPP), or Botblox DroneNet/Ethernet nodes over DroneCAN — configures NET_* directly, with CAN param Get/Set + endpoint passthrough for DroneNet. Auto-shows on NET_ENABLE.
Just added a feature allowing easy upload and management of Lua Scripts to the FC. It’ll also detect if scripting is disabled and let you easily turn it on.
Wow very nice!
“ I really like the idea of rails such as can only test motors if batteries are plugged in, etc.”
I would be on the side of let the builder decide in all matters. Possible a beginner and expert mode with expert allowing non lingerer decisions like Mission Planer. Thank you for your hard work!
Rails such as: only test motors when bateries are connected are good for all users.
What expert would want to test the motors without a battery? Is he really an expert?
Please remember that professional pilots use checklists.
Rails are good for beginners and experts alike.
Just a overall idea not stated verbatim. However If I like to setup the GPS or current settings at the end of the build who cares.
You can’t test without a battery everyone understands this however you can block the test page. This is more to what i was understanding your getting at.
Calibrating the compass requires GPS location.
Doing a magfit requires calibrated current measurements.
Guard rails are great, lots of users do not understand the depencies.
I’ve been using ArduPilot for four years, and the current interface hasn’t been easy to master. I appreciate finally seeing a more user-friendly interface, especially for young people starting out with ArduPilot who are used to more visual interfaces.
I’m looking forward to using the desktop version.
thanks for the feedback! much appreciated!
We actually have a desktop version for mac, windows, and linux here.
I just pushed a new release today so it should include all features in the webUI. I’d love some feedback as the desktop versions are minimally tested.
Of note, the web ui version should be able to be downloaded and ran offline in any chromium based browser.
All, providing an update, we have started to put a lot of effort into guided setup which should walk a user through all setup needed for basic flight. It is still very much in beta and a work in progress. This project is for the benefit of the community, so any feature requests or bug discoveries are much appreciated!!
in addition to this, theres a lot of common sense things we’re doing. examples would be if you set a compass type to canbus, it will stage canbus enable param changes, or if you set a port to a vtx protocol (tramp, smartaudio, displayport) it will stage param changes to set the vtx params up to match these changes.
all of these changes are staged, so it requires the operator to still be aware and write them.
Those are all steps in the right direction ![]()
Guiding the users while still giving them visibility and control over every single parameter change ![]()
Its kind of getting stuck at the step 2, idk the reason. Also I found some bugs and issues that is kind of annoying and ruining the UX. I’ll write in detail once ive used it enough. Rest of the features are good and easy for a webapp to have initial test. ![]()
thanks ! any feedback is awesome! especially the guided feature is a work in progress and we are working to get it there. its guys like you who spend the time that make the product great.
All,
providing another update. We have introduced some features where you are now able to create “presets” of parameters. the idea is you can set a number of parameters lining up against a specific sensor, FC, flight profile, etc. and it will save that to your presets tab. this allows you to select multiple presets for builds depending on what you’re putting onboard and you aren’t tied to an entire parameter upload that may or may not differ in some ways from your current build
ideally we will be able to build a very large preset library with the help of the community akin to betaflights where entry into configuration would be significantly improved and simple.
All,
Added readout of the live servo PWM’s to assist with troubleshooting, and an update bootloader and enter dfu button in the flash tab.
Can you increase the .bin log list download timeout from 3000ms?
It’s too short for F4 FCs with > 200 .bin log files stored in the SDcard.
I had the log-list timeout at 20 s, but the mavtftp directory listing loop was at 3 seconds per, I upped that to 20 s. Do you think that’ll suffice?
Yes, i think that is fine, thanks.
