Andrunav telemetry failing to connect to mission planner via UDPCI
i am working on an autonomous rover which acts as a testbed for what i will put on my autonomous boat, everything works, it drives already on its own.
for telemetry i was thinking about using andruav on a redmi 9 connected via usbc to my corewing f405, i can connect successuflly to the web interface, it shows the rover moving on the map.
but when i try to connect via updci on mission planner it goes on timeout, i’ve even checked via wireshark the packets and mission planner was sending the packets to the server but it was not recieving anything back.
does anyone know how to solve this? i’ve tried basically everything…
@MHefny do you have any ideas?
I will fix it witthin few hours.
Please try now… it was a firewall issue.
Looks like a cool project - what car chassis did you use here?
(post deleted by author)
A cheap rc car that was gathering dust in my basement, i bought a brushed esc so i could use the original motor and replaced the original proprietary servo with the one i already had available
Awesome. The best gear is the gear you already have!
ok so uh nothing seems to have changed, i am able to ping the server but when i connect it goes in time out, same as before fix, ill try the web plugin route in the meanwhile
