Analog video conversion to digital
hello everyone, i have a fpv setup and planning to get the video feed onto a separate VRx,
would you kindly suggest a robust converter to convert my analog signal to a digital one so that i can run deep learning operations on it
I believe this sort of conversion is possible, I’m not sure how practical it would be.
There are devices like this thing which will convert an analog signal input a digital output.
Based on the user review, it looks like it takes a lot of technical knowledge in order to use it.
I think there a reason most AI applications start with a digital signal.
When looking around for these sorts of devices, I did come across this more expensive converter.
The company selling it has an article discussing its features. The video converter is mention in the section titled: New Solution! Viewtron Analog to IP Video Converter
I personally don’t know how well any of these devices work. I don’t know enough about any of them to recommend them.
Following up on @ddegn If you want real time, There are quite a lot of ICs that convert AV video to other formats e.g
https://www.aliexpress.com/item/1005007939514681.html
https://www.aliexpress.com/item/1005011582073879.html
You can also get video recorders to record your flights to sd card etc
https://www.aliexpress.com/item/1005009730281234.html
thank you, will check them out
Thanks for the links to those video converters.
Any particular reason you linked to the video recorder you did?
I haven’t used that one personally but I have a variety of other small DVRs.
Here are two smaller and less expensive devices.
https://www.aliexpress.us/item/3256807741930030.html
https://www.aliexpress.us/item/3256806768971972.html
The second one has a small LiPo which I personally dislike. I don’t want to have to worry if my DVR charged before flight.
If anyone is recording video onboard, you might want to add a microphone.
https://www.aliexpress.us/item/3256808846561712.html
I have a couple of these microphones but I haven’t tested them yet.
