Analog to digital
I have an analog fpv camera I want to make it digital. Do you have any idea how can I do that?
You need PAL to MIPI converter.
IMHO you will be better off buying a digital FPV system.
If it was easy/cheap then it would be all over the place.
Easy: go buy walksnail (or digital system of choice, it doesn’t matter)
Hard (but maybe less money): check out things like https://openhdfpv.org/
what are you trying to connect the analog camera to?
Thank you all for your answers. I am trying to make a tethered drone.
  • I have matek fc I was trying to make a connection.
  • Since I have analog camera I would like to use it but if it is not practical I might buy new one.
If by tethered you mean you will have a cable from the copter to you, then you can try to lengthen then camera cable and connect it to your monitor.
What did you want to achieve by connecting the camera to the FC?
completely wired system, to get Osd
okay. that should be possible.
connect the camera as normal to the FC’s camera input, then connect your long cable from the FC’s VTX and ground pads to your monitor.
The cable likely will have to be coaxial and you may need signal amplifier as well as display with appropriate analog input.
Thank you I will try it
