Analog FuelSensor without the designated ADC Pin
I am currently building a fuel powered small model plane. My fuel tank has a built in analog fuel level sensor that I want to use.
From source documentation on ardupilot (Fuel Flow and Level Sensors — Copter documentation) they say I need to connect the output to the ADC Pin (RAW_PRESS_SENS_IN) however my carrier board (Airbot Systems Mini Carrier Board) for my Flight Controller (Cube Orange Plus ) does not break out this pin?
Is it possible to use one of the analog pins from the battery monitors to do this?BATT_VOLTAGE_SENS or AUX_BATT_VOLTAGE_SENS
Or is the only way to integrate this is with a different carrier board?
From the docs you linked to:
Any analog-capable pin can be used as the input from the sensor.
And the BATT parameters are given that need to be configured.
Max input voltage is 3.3VDC
So to use the BATT_VOLTAGE_SENS PIN on the carrier board
I would just setup the BATT_FL_PIN as 2: Pixhawk/Pixracer/Navio2/Pixhawk2_PM1 and not 12: CubeOrange?
The voltage pin on the Power1 connector on CubeOrange is 14
Thank you @dkemxr , i am able to get the raw voltage now I’m generating through DC power supply mimicking a ‘analog voltage’.
However with my current setup i can’t seem to get the ‘fuel level’ shown as a percentage.
At full a tank (15L) i am expecting 3.3v and at empty i am expecting 0-0,05V, however when i change these with my psu my HUD values for batt2 don’t change
These are all my batt2 related parameters:
BATT2_ARM_MAH,3000
BATT2_ARM_VOLT,0
BATT2_CAPACITY,15000
BATT2_CRT_MAH,3750
BATT2_CRT_VOLT,0
BATT2_FL_FF,1
BATT2_FL_FLTR,-1
BATT2_FL_FS,0
BATT2_FL_FT,0
BATT2_FL_OFF,0
BATT2_FL_PIN,14
BATT2_FL_V_MULT,0.3125
BATT2_FL_VLT_MIN,0.05
BATT2_FS_CRT_ACT,1
BATT2_FS_LOW_ACT,1
BATT2_FS_VOLTSRC,0
BATT2_LOW_MAH,7500
BATT2_LOW_TIMER,10
BATT2_LOW_VOLT,0
BATT2_MONITOR,24
BATT2_OPTIONS,0
BATT2_SERIAL_NUM,-1
BATT2_WATT_MAX,0
Where would i expect to see the ‘fuel level’ in mission planner, under current2?
That’s on the Wiki page in the link I posted.
And anytime you make changes to the battery monitors parameters you need to power cycle the Flight Controller.
hi dave, sorry i can’t seem to see the link?
Would you mine resharing it
Sorry, that was your link.
Check the status screen.
