Hi Greg, sorry to bother you.
How do you connect a FrSky X8R with the PixHawk2.1? I am not sure what cable!?
My Taranis X9D+ has been upgraded to OpenTX v2.2.1, no problems. Now I am a bit stuck regarding hardware connection.
You are so good in explaining things.
Sorry, I just found your answer at – FX-79 Buffalo QuadPlane Conversion –
I made a quick demo showing some of the features in the Yaapu LUA Telemetry. My MavLink Message screen didn’t have much on it because the quadcopter had been on for a while. Normally, the message beeps are heard for each message as the Pixhawk initializes and GPS get a 3D lock.
Having GCS-like telemetry right on the Taranis transmitter is very convenient. It is a great application so give it a try!
Hi Alex thanks a lot for this wonderful script ! I’m testing it on Taranis X9DE+ SE and when I run it I got “Script Panic not enough memory”: Any glue what could cause this error ?
also make sure the radio is not trying to compile the script: remove the yaapu9.lua file and only leave the yaapu9.luac one.
If the script does not start then try to rename yaapu9.luac in yaapu9.lua.
I had reports that sqt5font needs to be unchecked for memory hungry scripts to work
Hello Dave,
Follow the link in the first post to Alex’s github page. There you will find his script,and links that will show cables, pixhawk setup . And those linked pages offer even more info.
Once you have the script installed and running on your radio, the cable connected and configured to pixhawk, you’ll see everything on your radio.
