Hi Roland,
that’s my fault!
There was a bug in OpenTX 2.2.1 and I detect OpenTX version 2.3.1 as 2.2.1 and apply the fix anyway which mirrors the screens diagonally
I’ll fix it asap!
Hi Roland,
that’s my fault!
I’ll fix it asap!
Great Alex:grinning: you are the best
Jakob,
gas suite is supported using user selected frsky sensors as described here, @yak-54 might have a ready made config file for you
You will have frsky scheduler issues only if you add additional frsky sensors on the s.port bus along the GAS Suite, this is what @yak-54 found out which was solved by this patch not yet in master
Roland could you test this patch?
Simply copy it to the /SCRIPTS/YAAPU/LIB folder overwriting the existing one
draw.luac.zip (4.0 KB)
Dave, takeoff flight mode is now supported, both in stable releases and in the latest horus beta, let me know if it works as expected!
this is my config file for yaapu put it in yaapu CFG folder and rename it to your modelRENAME_TO YOUR_MOLER.zip (1006 Bytes)
Alex-Yes, working well. Thank you!
Hello Alex, just arrived and did a quick check - - now it looks like expected with opentx 2.3.1 and copter 3.9 and 4.0.dev.
Thanks allot
Thanks Roland, I’ll publish the patch on github later tonight!
Thanks too to You Alex,
another thing I don’t know if its related to 2.3. version - when changing model the screen shows only Disabled. After restarting TX everything runs normal. If I remember well this was different in previous version.
Greetings
Roland thanks again, that’s another little bug
Hi all,
I released version 1.8.1 beta2
horus_1.8.1_beta2.zip
changelog
version 1.8.2 beta
version 1.8.1 beta
Setup guide is here
Good evening Alex,
again me
Had a short flight with Cube black on Copter 4.0.dev and 1.8.1_beta2. Looks pretty good to me:+1: just one thing I want to mention is the nice yellow lines in the artificial horizon on the map view at the left upper corner (which are visible at your screenshots) is not shown on my Horus X10 with 2.3.1.
greetings
That’s 3 bugs in 2 days, you have won a rubber duck
Thanks for the feedback Roland, really!
fixed this one too, please redownload the zip file
Good evening Alex,
just did a bench test with the updated zip which confirms you great work
ok I would like the acid green rubber duck
greetings
there you go
Real basic question from a learner
I have a
Matek F765 Wing FC
FrSky R-XSR
Can I directly connect the S Bus to this FC?
If so can anyone help?
Taranis 9D Plus, Yaapu script running
Big thanks to Yaapu for making this possible
Rob
Not really a question for this thread but sure you can. It’s connected to UART6 (Rx6)
Appreciated.
Maybe I have it wrong then – I have:
S.Port — TX4
S Bus OUT — RX6
Is that correct?
(If I’m hogging the thread, then I can ask somewhere else… I don’t know where else!)
Thx
