- When arming the Copter the DAlt and Alt fall bellow zero.
- Entire mission is of 5 meter altitude and the RTL Max Alt is also 5 meters but there is small change in altitude when RTL.
- When Landing back both the DAlt and Alt gose into deep -ve values?
Could Someone justify this log, Please…
Log is attached.46.BIN (998.6 KB)
The altitude dropping below zero on arming is probably ground effect. The baro is seeing a pressure increase, which it interprets as a lower altitude. On the ground, DAlt will follow that.
The increase in altitude upon RTL is is probably the RTL_CLIMB_MIN value. It will pop up that amount regardless of circumstance. I can’t say with 100% certainty that applies to the RTL command in a mission, but I would think it does and that’s what that graph looks like.
Upon landing, the same thing is happening to the altitude as it did when you took off.
