I’m running a Pixhawk with v3.1.1 in a fixed wing (Talon) with a airspeed sensor.
I enable the ARSPD_AUTOCAL to calibrate the sensor, at the end of the flight the graph shows this.
This is correct? it´s normal all the peaks in the arspd graph?
I also post the log file from the flight.
Actually I have an I2C Airspeed sensor that works and flew it several times.
BUT I cant find in the Full Parameter list the ARSPD_AUTOCAL parameter to calibrate it.
I want to calibrate it because I think it needs.
@Lbarreiro,
That log looks reasonable, except that airspeed is quite a bit noisier than we really expect. Is the sensor in clean air?
Also note that a tlog is needed to properly analyse the airspeed learning process.
Cheers, Tridge
