Hello!
I have an arm precheck failure : AHRS not healthy when I have INS precheck turned on.
Could you please recommend how I can fix it?
Of course I can disable INS validation but it is better to investigate the problem
Thanks!
Hello!
Thanks!
Fixed by disabling compass because I don’t have any
I wrote an issue for the developers to look at in github: https://github.com/ArduPilot/ardupilot/issues/13110
Thank you for your report!
Disable ekf 2 and you could arm. I had same issue on my omnibus f4 v3 pro.
Look for ahrs in params (qgc), if I remember well : ek2_enable
Hello!
Do you mean disable Ekf2 filtering?
Hmmm… It’s too much for me. I prefer to have this feature enabled in my flight.
I’d just disabled magnetometer. Moreover, omnibus doesn’t have any.
Disable ekf2 is not a problem and it was like that until arduplane 3.4
Commercial solution like sensefly ebee flown without ekf. Ekf smooth your flight, if you use it as mission planning it’s better without ekf as it flies straight without smoothing curves …
Thanks for explaining this.
I will test disabling Ekf2 in my current build
Hi Naterater, the github issue is colsed and as far as I understood there I should set compass_use to 0 but it does not work for me. I still get the error about unhealthy AHRS.
Additionally I set compass_enable also to 0. No improvement…
I use arduplane 4.10 with Matek H743 with gps (BN220) but no compass.
Any help is appreciated!
Olaf
У меня такая же проблема проблема. Полетный контроллер Matek h743 wing v3 и GPS Ublox GPS NEO-M8N ready to sky . компас не колибруется и ошибка AHRS. Попробовал те советы которые здесь написаны и ничего не помогло…
