After a successful connection to Missioj Planner on my laptop I confirmed that there is no interference with the GPS like I had with the other 500 mW telemetry unit on my other Tarot quadcopter.
Next, I removed the propellers because I wanted to arm and run the copter and switch from Stabilize to Autotune. When I did so, Mission Planner indeed confirmed that the mode had switched to Autotune but a couple of seconds later, the aircraft disarmed itself. I’m afraid to try to fly this quad and switch to autotune until I understand why it disarmed itself.
Could it be that the copter sensed that it was not flying?
Actually, my objective was to see if the copter would switch to Autotune, which I confirmed did happen. Previously, with my other Tarot quad, when I switched from Alt-Hold to Autotune, nothing happened. I have now since confirmed that both aircraft will change modes.
