In my quadcopter, the #4 motor (Test Motor B) spins faster at Arm then the other 3 motors. The other 3 motors appear to spin the same. I assume this is not how it should be. How can I (should I) adjust the pwm of that single motor to match others?
Make sure RC calibration is done correctly, then run the semi-automatic ESC calibration. Then test each motor with the MissionPlanner motor test.
https://ardupilot.org/copter/docs/esc-calibration.html#semi-automatic-esc-by-esc-calibration
Would there be a telemetry log if I am just arming and spinning on ground / low throttle? Maybe that can give insight into specifics if required.
A telemetry log is not useful. If the craft is armed there will be .bin flight log on the flight controller. That’s useful.
That’s what I meant…sorry
