I tested the Autoland feature in version 4.7 Dev with some success. I upgraded to version 4.7 Beta and now I would like to add a rangefinder
Fixed wing frame (motorglider fitted with an airspeed sensor)
FC Matek: H742 wlite
Rangefinder: MTF-01P on UART8 SERIAL5
MTF-01 is configured for output protocol as “mav_apm” by using MicoAssitant
below are new settings on FC:
SERIAL5_BAUD 115
SERIAL5_OPTIONS 1024
SERIAL5_PROTOCOL 1
FLOW_TYPE 5
RNGFND1_TYPE 10
RNGFND1_MAX_CM 800
RNGFND1_MIN_CM 1
RNGFND1_ORIENT 25
RNGFND_LANDING 1
At power up I now have this warning:
d
k’ must not be set: use MAVn OPTION bit 1 instea
PreArm: SERIAL5_OPTION bit 10 (no forward mavlin
Not sure how to deal with this warning to stay on the safe side
Any help would be appreciated
iampete
(Peter Hall)
March 11, 2026, 1:05pm
2
We moved the functionality of the parameter. Set SERIAL5_OPTIONS to 0 and instead use the corresponding MAVx_OPTIONS bit “Don’t forward mavlink to/from”. To work out which MAVx parameter it would be you count the number of serial ports set to MAVLink 1 or 2. So if serial 1 thru 4 are also MAVLink then it would be MAV5 if only 1 and 2 are MAVLink then it would be `MAV3` ect.
Thanks for your quick reply
So in my case
(SERIAL0_PROTOCOL 2)
SERIAL1_PROTOCOL 2
SERIAL2_PROTOCOL 2
SERIAL3_PROTOCOL 5
SERIAL4_PROTOCOL 5
SERIAL5_PROTOCOL 1
means I must now set MAV3_OPTIONS to: Don’t forward mavlink to/from
iampete
(Peter Hall)
March 11, 2026, 1:51pm
4
I forgot about SERIAL0, it also counts so it would be MAV4_OPTIONS
