Most circuit boards do not have as many as 32 PWM outputs, so I added a feature to the serial port to output SBUS channels 17–32. The code was written with the help of AI, and the implementation has been verified using a logic analyzer.
This setup allows users to easily output a higher number of channels by using an SBUS-to-PWM converter module.
https://github.com/wsnfly/ardupilot4.7.1/commit/96a5c44159dd21adea1e673a8e257961b4a1b758
This is the modified section.
Important: The code was modified by AI. You must review it before use!
