Add more than one vehicle to mavproxy or mission planner
No matter what I did in Mavproxy, I couldn’t add the second plane. INo matter what I did in Mavproxy, I couldn’t add the second plane. Is there a line of code for this or is it done through the interface? Similarly, in the mission planner, I right-click on the upper area and say connect, but I still can’t connect the second plane. My goal is to combine the two planes on a single map and have one follow the other using telemetry data. This will be completely on the simulation.
Thank you very much…s there a line of code for this or is it done through the interface? Similarly, in the mission planner, I right-click on the upper area and say connect, but I still can’t connect the second plane. My goal is to combine the two planes on a single map and have one follow the other using telemetry data. This will be completely on the simulation.
