You have to perform the compass calibration again after a reset to default. Do the best you can with the manual method then use Magfit for the final calibration.
so I understand that there is a hidded parameter that states if mag is calibrated or not…
The parameters I have work perfectly on this uav, I just presed reset to default by mistake.
It’s dificult to remake the calibration, because I am alone in the field, and it’s 25kg uav…
Can I send command or make something to not remake the calibration process? and simply make that the arducopter accept the parameters the work perfectly ?
I discover that there is the same thing for the accel params…
