Hello !
I’ve updated my hex version to 3.2 and my Mission Planner to 1.3.16 and now I’m trying to install my parachute on my copter. I’m using a Opale Paramodels chute.
The problem I have is that in the “Full Parameter List” menu, I don’t see anything that is displayed here: copter.ardupilot.com/wiki/parachute/
Another problem is that on “Extended Tuning” menu, the CH 7 & 8 sometimes display and sometime don’t display the parachute options “Parachute Enable/Release/3pos”.
If I use the APM Planner v2.0.15, I can see the options to to Enable/Disable Parachute (CHUTE_ENABLED), to set the Parachute type (Relay / Servo), Parachute On/Off PMW, Parachute Min Alt, etc. , But whatever I click, the console of the APM Planner says: ’ ABORTED PARAM SEND, NO VALID QUARIANT TYPE. PARAM NAME: “CHUTE_ENABLED” Type: QVariant::Invalid ’
What should I do next ?
