I am using a A8 mini cam paired to a cube orange plus through uart for gimbal control.I was able to control and trigger camera to take both photos and videos which was then stored on the FAT32 formatted 64GB SD onboard the camera and also i was able to stream the video through ethernet on my laptop.Now after a firmware update to both gimbal and camera, the camera is no longer working and give 2 red and 1 yellow error after booting.I am using a 6S 8000 mAh LiPo battery to power the camera up and i am still able to control the gimbal and stabilization works fine but the camera is not responding or streaming videos even if i connect the camera directly to my laptop through ethernet.
For firmware update i used the latest firmware available Gimbal firmware v0.4.3 and for camera firmware i used v0.3.2.I did the gimbal update first and then the camera update. I followed the instructions given on the SIYI manual to update camera firmware through sd card. I have properly formatted the card to FAT32 and then copied the bin file to the root directory and let the camera run for more than 10 mins but after restarting the error started to show up.
The error LED sequence is 2 RED and 1 YELLOW
Can any one suggest me any fix for this? @SIYI could you look into this problem
Hello SIYI support,
Is there any timeline for the solution that can be given for this issue. If so kindly mention the timeline that is required to bring out a solution for this.
I received the non-public recovery firmware from SIYI but still cannot complete a camera firmware update to a solid green indication. I think there’s some sort of hardware corruption going on now. Not sure what to do.
