A small VIO system using OpenMV AE3 and Raspberry Pi
Hi @chobitsfan,
Really great progress! I saw your YouTube videos pop-up on my feed a couple of weeks ago and so it’s great to see this post with more details.
So I guess the VIO calculations are all done on the RPI5 and I guess there is also a small autopilot under the Pi?
I must admit I’d never heard of Kimera-VIO until I saw your videos. I guess what’s special about it is that it seems to work with just a single lens camera?
I don’t want to divert your efforts but I also wondered if it might be possible to run Kimera-VIO directly on one of the Siyi camera gimbals which can now accept open source AP_CameraGimbal software. TBH, I doubt if it would work because only the larger Siyi camera gimbals have a powerful enough linux CPU on board (the A8 is likely too slow)
I also wonder if I might be able to put it on my aerial photography copter that uses either an RPI-CM4 or CM5. The latest version has a camera gimbal directly connected to the PI so latency is low.
I hope it’s OK, I promoted this to a Blog post and moved some links around so that it appears on the front page of ardupilot.org gets a bit more visiblity. TBH, I’m slightly unhappy that we’ve blogs lower down on the ardupilot.org page but that’s another matter! :slight_smile:
