Hi people
Me and a buddy of mine decided to create a 7 inch racer drone. We plan to use 2508 2100kv AirA motors. The copter will be around 600g (+100 or -100) without te battery. I plan to use 6s 2100mah 30c battery. But dont think the C rate is enough. I cant find one with higher C rate and some people recommend me to use two 6s 1050mahs with 75c…
I think most 7" frame nearly 400 to 600gms but I think your plane is little bit heavy , also 2100mah battery for long rang like 2100 to max 3000mah on 7" and yes you can go with 1700mah with max “C” rating because your motor as you describe “2100Kv” it’s current hungry hope you think about your motor kv
I dont get what hungry hope is or anything you said in last sentence ( english is not my first language ) also the motors are 1200 kv and 2100. And Is 800 to 900 grams really that heavy i mean i will have enourmous thrust rates with motors that big
If we assume a Take Off Weight of ~975g (375g battery) it would have the potential to pull ~110A max so if you were using a 2100mah battery a ~50-75C would be a good choice.
