6M LZ129 Airship
Hi, I am working towards building a 6M model of the LZ129 Hindenburg. It will have neutral buoyancy so I am wondering which version of Ardupilot I should use. Copter may become confused when the motors are horizontal for forward thrust. Blimp does not seem useful as it is a monster without anything flapping (I hope). Any ideas would be welcome.
I am currently building a 1M version to test out the electronics (DroneCAN based), the construction and other elements but that will not have neutral buoyancy so needs to have Copter H frame (unless anyone has any ideas for that)
Thanks in advance,
Richard,
EDIT: see next few posts where it’s pointed out that a recent feature adds motor support to Blimp.
Unfortunately, it looks like Blimp still only supports flapping fin propulsion. Copter is definitely the wrong (and possibly worst) choice. Plane is likely more suitable, see link below.
If it were mine, I might try using a skid steered Rover/Boat implementation with a Lua script for altitude control.
Thanks for your reply Yuri. I have only chosen Copter for the 1M testbed as it will not have any buoyancy itself. I have had Sub suggested by AI and that is an interesting thought: airships and submersibles do have similar requirements and attributes. Just not sure how it would work. Plane does seem feasible, just need to make sure that it knows that zero forward speed is acceptable, as is going backwards. I will have a look at the rover and boat options and try and work out how to make LUA work with it.
Best regards,
Richard.
I hesitate to recommend Sub, as it has diverged quite a bit from the main branches of ArduPilot. I understand why it’s possibly attractive, and maybe it’s worth a go.
Plane is also a bit challenging, as you have to effectively ignore a lot of its built in protections and tuning.
It looks like my challenges are not just trying to get it built but to get it flying as well! I will look at plane in detail for this. As you say, I will need to tell it to ignore most of its safety features and take my word for it that the model will not crash :slight_smile:
Thanks for your input, I will let you know how I get on, if you are interested.
Richard.
Please post updates here, as I think there’s plenty to be learned from your project!
Will do. I have been very bad at documenting my builds (I suppose it is a reaction to my job). I will put together a Journey so Far with some pics of what I have produced so far and the lessons learned. Might take a while but I will get it done.
Cheers,
R.
Blimp have support for motor now : see https://github.com/ArduPilot/ardupilot/pull/29096 from this summer. We likely miss some documentation, but that should suite your frame
Thanks, @khancyr! I even briefly browsed the source and still missed that!
Thanks Khancry. I will check this out. I looked at the Blimp documentation on the website but it did not have this. I there anywhere I can see how to configure this?
Richard,
Just had a look at some updated Blimp documentation ( 4.8:29096/Blimp-motor-frame-and-AUTO by Hwurzburg · Pull Request #8135 · ArduPilot/ardupilot_wiki · GitHub ).
The section in question is:
Four Motor Blimp
The four motor blimp uses two forward-facing motors at the front for forward/back movement and yaw, one vertical motor for altitude, and one sideways motor for lateral movement:
MOTOR POSITION / DIRECTION SERVOx_FUNCTION
FRONT LEFT (forward thrust) Motor 33
FRONT RIGHT (forward thrust) Motor 34
VERTICAL (up/down thrust) Motor 35
LATERAL (sideways thrust) Motor 36
It seems that the four motors are two for forward and aft propulsion, one for sideways movement and one for vertical movement. Have I misunderstood?
Thanks,
Richard.
