40x HD Optical Zoom camera Thyea Z40
Hi, guys.
May I have your opinion about a new camera that has the thermal imaging function and the HD zoom function. If you have any suggestions for this product, please leave a comment below.
Weight 850g
Assemble:Detachable
Structural Rotation Range: Pitch:-130°~50°; roll:-75°~75°; head:About 175° Gimbal Control Range: Pitch: -100°~45°; head: -170°~170°
Static Control Accuracy: About 0.01°
Dynamic Control Accuracy: About 0.05°
Lens 40× zoom; aperture:F1.8~F3.6
Zoomable Yes
Video Resolution: 4K:8.29 million
Image Compressed Format JPEG
Video Compressed Format MPEG-4
Working Mode: Photograph, video
Storage Card: SD card (512M-2GB); SDHC card (4GB-32GB); SDXC car(48GB-128GB)
Temperature -20℃~60℃
Storage Temperature -30℃~70℃
Sensor CMOS 1/2.3inches
Zoom Times 40 times
Pixel/Resolution 25.60 Million
Now, let’s look forward to it.
Equipped with a precise 3-axial gyro-stabilized gimbal and MMC standardized quick release connector, Thyea Z40 is an extraordinary 40x HD optical zoom camera payload.
Standard Connector for High Compatibility
Thyea Z40 is installed with UAV payload standard connector, UAV equivalent to USB, that allows for quick installation and release with extreme convenience.
2. Compact and Lightweight
With compact and lightweight design, Thyea Z40 weighs only 600g, the lightest amongst its counterparts and compatible with various UAV systems.
  1. High-precision 3-axial Gyro-stabilized Gimbal
Thyea Z40 is equipped with a high-precision 3-axial gyro-stabilized gimbal system that is able to protect itself from high-frequency vibration. The gimbal uses the latest FOC brushless motor featuring precise and high-frequency response, avoiding shake to any degree during the flight. In the meantime, high processor can precisely control the operation of motor, adjust shooting angle and stabilize images even when it optically zooms up 40 times.
  1. Target Point Tracking
Once the target point tracking function is turned on, any target clicked on the ground station screen will be adjusted automatically to the center of the screen, and Thyea Z40 will automatically track the target.
  1. 40x HD Optical Zoom
Human faces that are 1200 meters away can be recognized by using the 40x HD optical zoom lens camera.
  1. 4K Resolution Recording Mode
Thyea Z40 supports video recording in 4K resolution with an ultra-high-definition image sensor.
  1. SuperHigh-Resolution Photograph
By adopting the latest CMOS sensor, the camera pixels can be up to 4992×2808, which satisfies the requirements of professional HD photographs.
  1. Photograph with Accurate GPS Information**
All the photos taken by Thyea Z40 come with high-accuracy GPS information, which is useful for problem tracking and solving in later stage.
  1. Gesture Zooming**
Thyea Z40 can zoom quickly and easily with a simple gesture on the screen.
  1. Double Shock-Absorption**
Thyea Z40 is with a special gimbal shock-absorption design to isolate itself from vibration during flight so as to capture stable and smooth real-time image.
  1. Tamper-Proof Industrial CAN design**
    Thyea Z40 shooting system with industrial CAN design is highly tamper-proof.
