@ 0 rpm(before arming) , ecs report 18A (same for all ECSs), should be 0A
@ 0 rpm (before arming), FC report 4A, should be 0.2A as measured
i try to ajust with BATT_AMP_OFFSET and BATT_AMP_PERVLT but i definitely return to default parameter because this issue cannot be solved with a simple ratio and offset (seems to be not a linear correction…)
Could you please help to understand what’s wrong in my setup?
unable to add zipped BIN log file here .. over 8Mb…
Yes i fallow manual calibration guide and Matek recommendation too, so i already set:
BATT_CURR_PIN to 11 and BATT_AMP_PERVLT to 40
Both parameter handle the read ADC mV input pin (“CUR” pin on the matek FC) and computed Vbat Current used by Ardupilot and display in MP. mV is comming from build in power CMS resistor (shunt) on ESC.
i understand that at low current the calculated current has a very poor accuracy. this could explain why 4A display for 0.2A real current?.? huge poor accuracy!
Am’i wrong?
So i don”t understand what’s wrong… hardware issue?
About Esc1/2/3/4.Current value coming from esc Telemetry ?
i read that telemetry value (including current for each ecs) could comes from bidirectional Dshot Motor wire M1/2/3/4 (pad S1 to S4 on matek fc) OR via command RX via the UART (SERIAL5 = UART8 for Matek Fc)?
it’s not very clear for me!… and if the current report wrong value by esc, it will definitily an ecs issue?
note: i ‘ve tried with same ECS hardware but brand new part => same result ! may be i’ve to change Sequre supplier by an other…
If the Sequre sensor won’t cooperate and you end up looking for another option, inexpensive ACS758-based sensors like the one below have worked well for me.
We fly drones with enormous complexity, PID, filtering, etc., but we failed with read an accurate battery current at full range. @SEQURE@MATEK
I’m going to integrate a Matek I2C-INA-BM board.
Do you have any experience with this board using ArduPilot?
Accuracy at low current, up to 50A? Coulomb metry? Is the flight time calculation ultra-reliable?
thank you again for the time you spend for my issues!
