those two .apj files are equal (both when using md5sum and cmp commands.)
Any other ideas?
-Lua scripting is not enabled. I cannot think of any reason for this to happen.
There are no EK2* params anymore.
And EK2 was disabled long before the upgrade (EK2_ENABLE,0)
There are 300 SRTL_POINTS - which I believe is default.
FWIW: I also re-flashed the firmware automatically selected by QGC.
Why do that. Use Mission Planners load custom firmware option and select the downloaded .apj.
Could be the same.
Yea there are, they are disabled. It goes away in 4.6 There was a time when updating from an old version this was still sometimes enabled. Not the case here as you say.
My first flashing was manual downloaded .apj because first attempt on auto-download by QGC failed. The second was just … to eliminate any potential chance of bad data aligning with a checksum and the universe
I am not involving windows in things that fly, hence no “mission planner”.
