I have built a quadcopter with the following components, and I would like to ask the experts to take a look at the setup, before the very-first flight of the quadcopter:
FC: Micoair H743
Ardupilot 4.6.3
ESC: Micoair Bluejay 50A 4-in-1
Battery sensor: Mateksys I2C Power Monitor I2C-INA-BM
Battery: 6s3p EVE-40PL 4000mAh 21700 pack
Motors: EMAX ECO2 3115 400KV
Prop: 12x7.5x3
GPS: HGLRC M100-5883 M10 GPS Module with Compass
Compass: The compass on FC is not used, the external one on the GPS module is used (GPS is mounted on a 23cm standoff to avoid interference with battery and high currents)
I have used AMC to configure the craft, and I reached the step where the very first flight should be made. Step 18, Notch filter setup is done.
Is there anything in the setup files, where I might screwed things up?
Are the default PID values safe for this huge copter? AMC support odcumentation mentions that βLarger vehicles usually require higher than default PID rate values.β Is this vehicle considered as larger?
Is there any abvoius issues in the config files?
No. A 12" isnβt considered large. Well, maybe if you have only built 3-7" craft it might seem that way. The default rate PIDβs, which are based on a generic 10" craft, should get it in the air OK for 1st flight. I would suggest the 1st things to review in the log and adjust but you are working in the AMC so you will arrive there anyway.
Follow the recommended steps, those are been tested hundreds of thousands times and produce good results.
The problems come when people start misinterpreting the documentation or ignoring the documentation. That is why AMC was created, to reduce the amount of documentation you need to read and interpret. If there are decisions that can be automatically done, AMC does it for you, so that you do less mistakes. This forum is full of users that misinterpret documentation or do not read it.
A 10ββ drone is nothing special, ArduPilot can control it fine!
