Yes, I was in Loiter mode, I flew quite high, I put throttle in lowest position, after several seconds, the drone was still like 20m high in the air, I can see the machine stopped, crashed down immediately. After I go back home, I check all my drones, I can find any time I put throttle at lowest position after 10 seconds, machines are all auto disarmed, I check source code, from there, I found a parameter called “disarm_delay”, default is 10 seconds, now I change it to 30 seconds, at least I will not put lowest throttle for 30 seconds long when drone is in air.
I have not really deeply studied the program, my current question is:
Is it a system design, whenever system check the throttle at lowest position reaching Disarm_Delay, it will automatically disarmed even the machine is in the air?
Thanks.
Below is related source code, sounds system will auto disarm no matter in any kind of flight mode:
void Copter::auto_disarm_check()
uint32_t tnow_ms = millis();
uint32_t disarm_delay_ms = 1000*constrain_int16(g.disarm_delay, 0, 127);
// exit immediately if we are already disarmed, or if auto
// disarming is disabled
if (!motors.armed() || disarm_delay_ms == 0 || control_mode == THROW) {
auto_disarm_begin = tnow_ms;
return;
#if FRAME_CONFIG == HELI_FRAME
// if the rotor is still spinning, don’t initiate auto disarm
if (motors.rotor_speed_above_critical()) {
return;
#endif
// always allow auto disarm if using interlock switch or motors are Emergency Stopped
if ((ap.using_interlock && !motors.get_interlock()) || ap.motor_emergency_stop) {
#if FRAME_CONFIG != HELI_FRAME
// use a shorter delay if using throttle interlock switch or Emergency Stop, because it is less
// obvious the copter is armed as the motors will not be spinning
disarm_delay_ms /= 2;
#endif
} else {
bool sprung_throttle_stick = (g.throttle_behavior & THR_BEHAVE_FEEDBACK_FROM_MID_STICK) != 0;
bool thr_low;
if (mode_has_manual_throttle(control_mode) || !sprung_throttle_stick) {
thr_low = ap.throttle_zero;
} else {
float deadband_top = g.rc_3.get_control_mid() + g.throttle_deadzone;
thr_low = g.rc_3.get_control_in() <= deadband_top;
if (!thr_low || !ap.land_complete) {
// reset timer
// disarm once timer expires
if ((tnow_ms-auto_disarm_begin) >= disarm_delay_ms) {
init_disarm_motors();
