V3.2.1 APM, Mind of its own, fly off
Hi
I have a DJI450 clone flying the HK pilot mega2.7. My first flight a few weeks ago. Was all going well until it got a bit out of control and I tried to land. I dumped the throttle hoping for a minor crash and then the machines took over and it decided to go for a wee flight by itself.
I could hear it changing flight modes continuously so I’m guessing the fail-safes were trying to kick in. Had a ringfence set at 30m and loss of signal ones etc.
Thankfully I had telemetry connection and I managed to track it to a neighbours place about 300m down the road.
I have looked at the KML and it looks like it had a nice little tour of my neighbourhood before coming to “land” in a garden.
I have attached the logs, any help as to why it flew off would be appreciated?
I’m scared to fly again until I work it out.
@DrXap,
Here is an Auto Analysis of your bin file:
Size (kb) 1840.146484375
No of lines 26363
Duration 0:14:24
Vehicletype ArduCopter
Firmware Version V3.2.1
Firmware Hash 36b405fb
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERRs found: FS_BATT FS_THR GPS_GLITCH FENCE
Test: GPS = FAIL - GPS glitch errors found (2)
Min satellites: 0, Max HDop: 99.99
Test: IMU Mismatch = UNKNOWN - No IMU log data
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = FAIL - Roll (-128.00, line 14968) > maximum lean angle (45.00)
Test: Thrust = GOOD -
Test: VCC = FAIL - VCC below minimum of 4.6v (4.523v)
Looks like you had a GPS issue as min sats are 0, HDOP is 99.99 and there were two GPS glitches.
Regards,
TCIII GM
I have similar problem my f45 went from Stabilize fashion suddenly like a rocket. here at my anelyse the bin file. I think my problem was set viritueel fencing. Greetings Van Den Berg
Log File C:\Program Files (x86)\Mission Planner\logs\QUADROTOR\1\2016-08-28 11-15-01.log
Size (kb) 1002.2890625
No of lines 15253
Duration 3 days, 18:30:52
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = NA -
Test: Balance/Twist = NA -
Test: Event/Failsafe = FAIL - ERRs found: FS_THR FENCE GPS
Test: GPS = FAIL - Min satellites: 0, Max HDop: 99.99
Test: PM = NA -
Test: Pitch/Roll = NA -
Test: Thrust = NA -
Test: VCC = FAIL - VCC below minimum of 4.6v (4.434v)
if this is a different problem and somebody knows what this causes you want to know this. by turning off the radio device still a real problem in the GPS system back on RTL landed so is still very strange
