I want to use a dc to dc stepup converter to run my camera in a plane with a pixhawk.
Will these modules interfere with my pixhawk? How close together can they be? Any one doing this wtih some advice?
Thanks
Jim
Thanks
Jim
The simple answer is, go for it. I am using and have used many over the years without any problems. I have used commercial ones, ones from China, and homemade ones. Of course,some may be worse than others, I keep as much distance as reasonable from the flight controller.
Don’t forget to re-calibrate your compass and run CompassMot after you modify your wiring.
Rick
Thanks IIamatrails for the reply. I was hoping to put it in the same compartment as the pixhawk.these are made by drok I believe.
Thanks again
Jim
