Updated my drivers on latest release still didn’t fix the problem. Still hanging on first frame.
Video card: Nvidia GeForce GTX 1060 6GB
regards,
Corrado
regards,
Corrado
Helllo,
I have the same problem with the latest mission planner hud hanging after the first frame from gstreamer (raspberry pi default version).
I tried to stream both the videotest with the bouncing ball and the raspberry pi camera feed.
Also tried with two different computers that both have the latest drivers for their respective hardware.
Please note that the feed works ok when I grab it from the target computer gstreamer or QGC.
Best regards,
Tasos Sangiotis
what version of gstreamer are you using?
On the host computer (the one equipped with mission planner) I was using
the latest stable gstreamer.
Just tried with gstreamer 1.9.2 as suggested above and it works fine. Sorry
for the inconvenience.
I am trying to use just a GoPro hero 4 silver edition to stream into the HUD of mission planner using gstreamer. I have no luck yet. Anyone done this before?
I will investergate getting a newer version working.
Have a similar problem. Using Telestream Wirecast to receive FPV via multiple cellular networks (720p25 @ 150ms latency). Wirecast creates a VirtualCamera-Output; works fine with QGroundControl. MP 1.3.47 was the latest working version for me.
can you give me more info on whats its actually sending?
Sry Michael for coming back late … RTP / 720p25 / h.264 /5600
hope that´s the info you´d asking for …
solved: happy to announce that my LiveFeed via Wirecast is working again with MP x.55
@Michael_Oborne & @peterbarker
I am using Raspberry Pi 4 (4G RAM) as companion computer to Pixhawk and able to connect to MP on TCP over Internet (via public cloud bypassing telecomm NAT)…all 4G/Cellular!.
Now, I am able to do Live streaming via running ffmpeg (on RPI4) over Youtube and same can be stream to VLC (Network Stream) on my desktop where MP is running.
Question: Any idea how can I direct ffmpeg streaming from RPI4 (on my quad) to MP’s gstreamer Port 5600 on my desktop PC?. **Note: I am using Debian instead of APSync (want to use 4G instead of WiFi)
Hello @Michael_Oborne: Yes , I am getting now UDP stream , following is step-by-step…
1/ both MP (on my windows desktop PC) and RPI4 (on quad) is on same WiFi LAN.
2/ same command executed in RPI4 , except usdpsink host is my windows IP (from same wifi lan)
Question: How can i rotate video in HUD and enable telemetry data?
can you test from a command line
C:\ProgramData\Mission Planner\gstreamer\1.0\x86_64\bin\gst-launch-1.0.exe “udpsrc port=5600 buffer-size=90000 ! application/x-rtp ! rtph264depay ! avdec_h264 ! queue leaky=2 ! autovideosink”
and confirm that this runs?
