Vibrations seems to be in the acceptable range ,but can be improved. CoG also seems to be good. Is the baro covered ?
Check throttle mid point. And I think it needs pid tuning. What about your flying experience ?
Thanks for your help
My first flying experience was quite good but last 3 flights my quad become erratic. I don’t have any video to show you but it’s really disturbing. it can’t keep stabilised. It lower 2m than try to climb 5m, go left, right …
i have already done compass and accelero calibration. Don’t know what to do
I’ve change 2 props kits and same, no amelioration at all.
But one thing I’ve observed that is one motor turning really hard than others. This can be my issue ??
You have some vibrations, although not excessive by any means, they are erratic.
Is everything tight on the quad?
Have you balanced the props?
Are the motors all aligned vertically?
Is the quad balanced?
Have you done an ESC calibration?
It is evident you were fighting the craft, especially pitch wise.
Have you done an autotune?
Thanks
Everything is tight. Props are well balanced. Waiting for dji original one to test them. Motors are aligned correctly. ESC calibration done. RC calibration too.
Will try autotune as soon as weather will permit. Still raining for 1 week. I will let you know.
